Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hamilton Beach 25460Z LED Replacement
Ce dont vous avez besoin
    1. Hamilton Beach 25460Z LED Replacement, Handle: étape 1, image 1 de 2 Hamilton Beach 25460Z LED Replacement, Handle: étape 1, image 2 de 2
      • Unplug your device before proceeding with disassembly.
      • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
      • Repeat for the other washer across from the first one.
      Demander à FixBot
      Ajouter un commentaire
    2. Hamilton Beach 25460Z LED Replacement: étape 2, image 1 de 2 Hamilton Beach 25460Z LED Replacement: étape 2, image 2 de 2
      • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
      • Pull the end of the bolt out to completely remove it.
      • Repeat for the second bolt.
      Demander à FixBot
    3. Hamilton Beach 25460Z LED Replacement: étape 3, image 1 de 2 Hamilton Beach 25460Z LED Replacement: étape 3, image 2 de 2
      • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
      Demander à FixBot
    4. Hamilton Beach 25460Z LED Replacement: étape 4, image 1 de 1
      • Unscrew the locking knob all the way to remove it.
      Demander à FixBot
    5. Hamilton Beach 25460Z LED Replacement: étape 5, image 1 de 3 Hamilton Beach 25460Z LED Replacement: étape 5, image 2 de 3 Hamilton Beach 25460Z LED Replacement: étape 5, image 3 de 3
      • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
      Demander à FixBot
    1. Hamilton Beach 25460Z LED Replacement, LED: étape 6, image 1 de 1
      • Gently separate the heating element housing from the cooking surface by pulling up on the housing and pushing down on the surface.
      • Pulling too far or too hard can break the delicate internal wiring.
      Demander à FixBot
    2. Hamilton Beach 25460Z LED Replacement: étape 7, image 1 de 1
      • On the underside of the housing, use the PH2 Screwdriver to remove the single 12mm screw to disconnect the LED tray.
      • The housing can now be completely removed.
      • Place on the side for reassembly.
      Demander à FixBot
    3. Hamilton Beach 25460Z LED Replacement: étape 8, image 1 de 3 Hamilton Beach 25460Z LED Replacement: étape 8, image 2 de 3 Hamilton Beach 25460Z LED Replacement: étape 8, image 3 de 3
      • Using the PH2 screwdriver, remove the single 10mm screw on the circular plastic LED tray.
      • Now remove the small plastic T-shaped piece and the plastic tray completely
      Demander à FixBot
    4. Hamilton Beach 25460Z LED Replacement: étape 9, image 1 de 1
      • Gently pull off the translucent bulb covers
      Demander à FixBot
    5. Hamilton Beach 25460Z LED Replacement: étape 10, image 1 de 3 Hamilton Beach 25460Z LED Replacement: étape 10, image 2 de 3 Hamilton Beach 25460Z LED Replacement: étape 10, image 3 de 3
      • Very gently, slide the white wiring covers down to expose the wiring connectors
      Demander à FixBot
    6. Hamilton Beach 25460Z LED Replacement: étape 11, image 1 de 1
      • Refer to this page to brush up on your soldering skills.
      • The LED can now be removed by desoldering the connector at each wiring junction.
      • The red LED connects to the red wire (positive) and the blue wire (negative, marked in yellow.)
      • The green LED connects to the white wire (Positive) and the blue wire (negative, marked in yellow.)
      Demander à FixBot
Katie Howes
Membre depuis le 02/01/15
288 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-27, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 membres
30 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 1,277
