Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hitachi CP-X440 Sensor Replacement
Ce dont vous avez besoin
  1. Hitachi CP-X440 Sensor Replacement, Sensor: étape 1, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    Demander à FixBot
    Ajouter un commentaire
  2. Hitachi CP-X440 Sensor Replacement: étape 2, image 1 de 2 Hitachi CP-X440 Sensor Replacement: étape 2, image 2 de 2
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    Demander à FixBot
  3. Hitachi CP-X440 Sensor Replacement: étape 3, image 1 de 3 Hitachi CP-X440 Sensor Replacement: étape 3, image 2 de 3 Hitachi CP-X440 Sensor Replacement: étape 3, image 3 de 3
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    Demander à FixBot
  4. Hitachi CP-X440 Sensor Replacement: étape 4, image 1 de 2 Hitachi CP-X440 Sensor Replacement: étape 4, image 2 de 2
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    Demander à FixBot
  5. Hitachi CP-X440 Sensor Replacement: étape 5, image 1 de 3 Hitachi CP-X440 Sensor Replacement: étape 5, image 2 de 3 Hitachi CP-X440 Sensor Replacement: étape 5, image 3 de 3
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    Demander à FixBot
Natalie Safron
Membre depuis le 03/21/22
221 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 370
