Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hot Tools HPK12 Control Assembly Replacement
Ce dont vous avez besoin
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 3 de 3
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      Demander à FixBot
      Ajouter un commentaire
    2. Hot Tools HPK12 Control Assembly Replacement: étape 2, image 1 de 1
      • Use the metal spudger to push the center pin through to the other side.
      Demander à FixBot
    3. Hot Tools HPK12 Control Assembly Replacement: étape 3, image 1 de 2 Hot Tools HPK12 Control Assembly Replacement: étape 3, image 2 de 2
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      Demander à FixBot
    4. Hot Tools HPK12 Control Assembly Replacement: étape 4, image 1 de 1
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      Demander à FixBot
    5. Hot Tools HPK12 Control Assembly Replacement: étape 5, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 5, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 5, image 3 de 3
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      Demander à FixBot
    6. Hot Tools HPK12 Control Assembly Replacement: étape 6, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 6, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 6, image 3 de 3
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      Demander à FixBot
Aaron Whitlock
Membre depuis le 10/24/16
249 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-4, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 34
Total : 3,221
