Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hover-1 H1 Power Button Replacement
Ce dont vous avez besoin
    1. Hover-1 H1 Power Button  Replacement, Bottom Shell: étape 1, image 1 de 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Demander à FixBot
      Ajouter un commentaire
    2. Hover-1 H1 Power Button  Replacement: étape 2, image 1 de 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Demander à FixBot
    3. Hover-1 H1 Power Button  Replacement: étape 3, image 1 de 2 Hover-1 H1 Power Button  Replacement: étape 3, image 2 de 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Demander à FixBot
    4. Hover-1 H1 Power Button  Replacement: étape 4, image 1 de 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Demander à FixBot
    1. Hover-1 H1 Power Button  Replacement, Power Button: étape 5, image 1 de 1
      • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
      • Pull the cable through the center section of the hoverboard.
      • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
      Demander à FixBot
    2. Hover-1 H1 Power Button  Replacement: étape 6, image 1 de 2 Hover-1 H1 Power Button  Replacement: étape 6, image 2 de 2
      • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
      Demander à FixBot
    3. Hover-1 H1 Power Button  Replacement: étape 7, image 1 de 1
      • Pull the power button through the hole in the shell.
      Demander à FixBot
Christopher Bruni
Membre depuis le 10/08/18
121 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 38
Total : 4,080
