Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hover-1 Horizon Power Button Replacement
Ce dont vous avez besoin
    1. Hover-1 Horizon Power Button Replacement, Base Plate: étape 1, image 1 de 2 Hover-1 Horizon Power Button Replacement, Base Plate: étape 1, image 2 de 2
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      Demander à FixBot
      Ajouter un commentaire
    2. Hover-1 Horizon Power Button Replacement: étape 2, image 1 de 2 Hover-1 Horizon Power Button Replacement: étape 2, image 2 de 2
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      Demander à FixBot
    3. Hover-1 Horizon Power Button Replacement: étape 3, image 1 de 3 Hover-1 Horizon Power Button Replacement: étape 3, image 2 de 3 Hover-1 Horizon Power Button Replacement: étape 3, image 3 de 3
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      Demander à FixBot
    1. Hover-1 Horizon Power Button Replacement, Power Button: étape 4, image 1 de 1
      • Reorient the Hover-1 Horizon so the base plate opens towards you.
      Demander à FixBot
    2. Hover-1 Horizon Power Button Replacement: étape 5, image 1 de 3 Hover-1 Horizon Power Button Replacement: étape 5, image 2 de 3 Hover-1 Horizon Power Button Replacement: étape 5, image 3 de 3
      • Remove the connector by squeezing the tab and lifting up.
      Demander à FixBot
    3. Hover-1 Horizon Power Button Replacement: étape 6, image 1 de 3 Hover-1 Horizon Power Button Replacement: étape 6, image 2 de 3 Hover-1 Horizon Power Button Replacement: étape 6, image 3 de 3
      • Remove the second connector by squeezing the tab and pulling up.
      Demander à FixBot
    4. Hover-1 Horizon Power Button Replacement: étape 7, image 1 de 3 Hover-1 Horizon Power Button Replacement: étape 7, image 2 de 3 Hover-1 Horizon Power Button Replacement: étape 7, image 3 de 3
      • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
      • Push the power button through the base plate to remove.
      • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
      Demander à FixBot
Christina Fong
Membre depuis le 10/08/18
165 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S13-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 26
Total : 888
