Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hover-1 Titan Power Button Replacement
Ce dont vous avez besoin
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: étape 1, image 1 de 2 Hover-1 Titan Power Button Replacement, Bottom Right Panel: étape 1, image 2 de 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    Demander à FixBot
    Ajouter un commentaire
  2. Hover-1 Titan Power Button Replacement: étape 2, image 1 de 2 Hover-1 Titan Power Button Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
    Demander à FixBot
  3. Hover-1 Titan Power Button Replacement: étape 3, image 1 de 3 Hover-1 Titan Power Button Replacement: étape 3, image 2 de 3 Hover-1 Titan Power Button Replacement: étape 3, image 3 de 3
    • Grip the bottom right panel and lift to remove it.
    Demander à FixBot
  4. Hover-1 Titan Power Button Replacement, Power Button: étape 4, image 1 de 2 Hover-1 Titan Power Button Replacement, Power Button: étape 4, image 2 de 2
    • Disconnect the battery by holding the yellow connectors and pulling apart.
    Demander à FixBot
  5. Hover-1 Titan Power Button Replacement: étape 5, image 1 de 3 Hover-1 Titan Power Button Replacement: étape 5, image 2 de 3 Hover-1 Titan Power Button Replacement: étape 5, image 3 de 3
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
    Demander à FixBot
  6. Hover-1 Titan Power Button Replacement: étape 6, image 1 de 2 Hover-1 Titan Power Button Replacement: étape 6, image 2 de 2
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
    Demander à FixBot
  7. Hover-1 Titan Power Button Replacement: étape 7, image 1 de 3 Hover-1 Titan Power Button Replacement: étape 7, image 2 de 3 Hover-1 Titan Power Button Replacement: étape 7, image 3 de 3
    • Pull the power button out of the panel.
    • Replace the power button.
    Demander à FixBot
Alexander Pham
Membre depuis le 10/07/18
221 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S15-G4, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 38
Total : 1,033
