Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Fix A Loose Bicycle Chain
Ce dont vous avez besoin
    1. How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: étape 1, image 1 de 2 How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: étape 1, image 2 de 2
      • Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
      • Your bike might have oil all over its chain and gear, so it's best to wear gloves.
      Demander à FixBot
      Ajouter un commentaire
    2. How to  Fix A Loose Bicycle Chain: étape 2, image 1 de 1
      • Use a bike stand or wall to help keep your bike from falling.
      Demander à FixBot
    3. How to  Fix A Loose Bicycle Chain: étape 3, image 1 de 2 How to  Fix A Loose Bicycle Chain: étape 3, image 2 de 2
      • Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
      • Be sure to not fully unscrew the nut or else the rear wheel will no longer be connected to the bike and you will have to spend time reassembling it.
      Demander à FixBot
    4. How to  Fix A Loose Bicycle Chain: étape 4, image 1 de 2 How to  Fix A Loose Bicycle Chain: étape 4, image 2 de 2
      • Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
      • Pull the wheel back from the frame.
      • Hold the wheel in place while proceeding to the next step.
      • While holding the wheel back, your chain should stop hanging.
      Demander à FixBot
    5. How to  Fix A Loose Bicycle Chain: étape 5, image 1 de 2 How to  Fix A Loose Bicycle Chain: étape 5, image 2 de 2
      • Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
      Demander à FixBot
    6. How to  Fix A Loose Bicycle Chain: étape 6, image 1 de 2 How to  Fix A Loose Bicycle Chain: étape 6, image 2 de 2
      • Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
      • Do not place your fingers too close to the bike gear. It may accidentally spin depending on how your bike works and trap your fingers.
      Demander à FixBot
After reading this guide you will never have trouble with a loose chain again.
8 autres ont terminé cette réparation.
Carlos Ortiz
Membre depuis le 01/30/22
325 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-17, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 4-17, Briggs Spring 2022
CSULA-BRIGGS-S22S4G17
1 membre
3 tutoriels rédigés
3 commentaires de tutoriel
The steps to tight the loosen chain are good. I will try it for my cycle. https://www.youtube.com/watch?v=JMdihKgC... speed internal gear bicycle). This video reflect your steps in a good manner
Kulasekara Pandian - Réponse Partager
Muchas gracias ! Me sirve muy buena información sin rodeos, y directo a los que se necesita gracias.
Martin alejandro Eligio avalos - Réponse Partager
Gracias por sus enseñanzas muchas bendiciones para todos ustedes.
Pablo Ventura - Réponse Partager
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 72
30 derniers jours : 392
Total : 32,964
