Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Fix the Indesit Washing Machine F06 Error Code
Tutoriel vidéo
Ce tutoriel a été transcrit à partir d'une vidéo YouTube.
Ce dont vous avez besoin
    • Switch off the washer and unplug it before touching the lower panel, filter area, or door lock area.
    • Stop using the washer if you smell burning electrical insulation or sulfur, and leave it unplugged until it has been inspected.
    • Don't force the door open if the drum is full of water or the water is hot.
    • The F06 error on these models indicates the door is stuck shut and won't release normally.
    Demander à FixBot
    Ajouter un commentaire
    • Switch the washer off at the actual plug socket.
    • Leave the power off for five minutes.
    • Try to open the door normally after the wait time has passed.
    • This reset may release the door lock without any tools.
    Demander à FixBot
    • Use the end of a spoon or a flat blade screwdriver to pop off the lower front panel.
    • Look on the right-hand side near the filter for the green emergency release cord.
    • Keep the washer unplugged while the lower panel is removed.
    Demander à FixBot
    • Pull the green cord downward to release the door lock.
    • Listen for the door lock to release.
    • If the door stays stuck, pull the cord up and down with a firm grip until the lock releases.
    • Pull the green cord down with one hand while trying to open the door with the other hand.
    • Use pliers to grip the cord if your fingers can't get enough leverage.
    • Don't crush or tear the cord with the pliers.
    Demander à FixBot
    • Inspect the door handle and locking lever after the door opens.
    • A handle or lever that looks broken may need a separate replacement repair.
    • Pull the green cord and watch the lock mechanism move up and down.
    • If the handle and lever look good but the lock won't release, suspect a fault inside the door lock or control system.
    Demander à FixBot
    • Use an old plastic card, not a real credit card.
    • Slide the card into the gap near the door latch.
    • Push the card against the latch area to try to release the locking mechanism.
    • This method may not work on every washer, but it can release some stuck latches.
    Demander à FixBot
    • Feed a piece of string or garden cord into the groove around the door.
    • Use a flat blade screwdriver to push the cord into the groove if needed.
    • Hold the cord at the top and bottom of the door.
    • Pull the cord toward the left-hand side to catch the locking lever and release the door.
    • This method may work on some washers even if the card method fails.
    Demander à FixBot
    • Use a large screwdriver to wedge the door open only if the washer is being scrapped or you accept the risk of damage.
    • Wear work gloves and keep your hands clear of the latch area while prying.
    • Expect this method to damage the door, latch, cabinet, or lock parts.
    • Don't use this method on a washer you plan to repair unless all safer release methods have failed.
    Demander à FixBot
    • Check whether the washer still reports the door as locked after the door is open and the power is restored.
    • A washer that still thinks the open door is locked has a definite fault in the lock or control system.
    • Replace a broken handle or lever if that is the only visible fault.
    • Get professional diagnosis if there was a burning electrical or sulfur smell, or if the lock fault remains after opening the door.
    • Consider replacing the washer if it is old, has electrical burning smells, or would need repeated call-outs and repairs.
    Demander à FixBot
After the door is open, don't run the washer again until the door lock fault has been repaired or diagnosed. A stuck door caused by a broken handle or lever may be worth repairing, but burning smells or a washer that still reports a locked door while open point to a more serious electrical fault. Repair didn't go as planned? Ask our Answers community for help.
eCuration
Membre depuis le 05/19/17
478 744 Réputation
396 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 28
7 derniers jours : 311
30 derniers jours : 1,036
Total : 1,472
