Introduction
Use this guide to remove the front panel in your LG front load washing machine.
Removing the front panel gives you access to the drain pump assembly as well as the drain hose.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
Ce dont vous avez besoin
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Disconnect the connectors attached to the control panel.
Remove the screw(s) securing the control panel to the top edge of the chassis.
Remove the screw(s) securing the detergent dispenser.
Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
Remove the control panel, making sure to thread any cables through the chassis.
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Use your fingers to pull the boot off its lip on the front panel.
Open the filter panel at the bottom of the front panel.
Unclip the filter panel.
Place a bowl next to the machine.
Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
Remove the plug at the end of the drain filter hose to release excess water into the bowl.
Pull the filter trim straight off the front panel to remove it.
Remove the screw(s) securing the lower front panel.
Pull the door latch through its slot in the chassis and let it hang on its wire.
Lift the front panel upward to separate it from its clips on the bottom of the chassis.
Pull the front panel away from the chassis to completely separate the front panel.
Repair didn’t go as planned? Ask our Answers community for help.
3 autres ont terminé cette réparation.
2 commentaires
Hi Bill, it is a good illustration. I have a different model with front cover has two pieces. LG WD1408NPW. Do you have any recommendations to remove this cover
