Introduction
Use this guide to replace the display adhesive in your Apple Watch and reseal it.
This is a general resealing guide based on an Apple Watch Series 6 44 mm. The resealing procedure for the Apple Watch Series 5 and newer models is more or less the same, despite slightly different inner workings.
You’ll need replacement adhesive to reattach the display when reassembling the device.
Ce dont vous avez besoin
Apply a little bit of isopropyl alcohol (>90%) to a cotton swab, or Q-tip (or use a cleaning pad) and gently remove the old adhesive on top of the watch frame.
Flip the Apple Watch upside down so the display lays flat and lift the watch body.
Gently remove the old adhesive on the rear side of the display.
Use a pair of tweezers to carefully remove the replacement adhesive (including the blue protective film) from the backing paper.
Hold the replacement adhesive diagonally and thread it over the display.
Slightly tilt the display forward to align the adhesive with the frame.
Position the replacement adhesive on the watch frame, where the old adhesive was located.
Hold the replacement adhesive diagonally and thread it over the display cables.
Slightly tilt the display cables forward to align the adhesive with the frame.
Lay your display flat on your working surface.
Hold the watch body in an upright position and grab the display cables with a pair of tweezers.
Align the display cables parallel to the ZIF connectors and push them in.
Use the pointed end of a spudger and fold down the black flaps on top of the ZIF connectors to secure the cables.
Carefully adhere the old heat dissipation stickers to the ZIF connectors on the rear side of the display or apply new heat dissipation stickers where the old ones were located.
Use tweezers and a pair of scissors to lift and cut a corner of the protective film.
Remove the film from the display adhesive.
Align the screen and press it down firmly onto the adhesive.
2 autres ont terminé cette réparation.
