Aller au contenu principal
How to Shorten Straps on a Tank Top by Hand
Ce dont vous avez besoin
  1. How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: étape 1, image 1 de 2 How to Shorten Straps on a Tank Top by Hand, How to Shorten Straps on a Tank Top by Hand: étape 1, image 2 de 2
    • Put on the top.
    • Hold and stretch the strap to the desired length.
    • Secure the desired length of the strap with a safety pin.
    • Be careful with the safety pin while securing the strap.
  2. How to Shorten Straps on a Tank Top by Hand: étape 2, image 1 de 1
    • Use a fabric pencil to mark both sides of the strap right above the safety pin.
  3. How to Shorten Straps on a Tank Top by Hand: étape 3, image 1 de 1
    • Remove the safety pin.
    • Use the ruler to measure the length between the two marks.
    • This length of the strap will be removed at the last step.
  4. How to Shorten Straps on a Tank Top by Hand: étape 4, image 1 de 2 How to Shorten Straps on a Tank Top by Hand: étape 4, image 2 de 2
    • Place the top down so the back is facing up.
    • Place one end of the ruler where the strap meets the back of the shirt.
    • Use the fabric pencil to mark the strap, using the measurement from the previous step.
  5. How to Shorten Straps on a Tank Top by Hand: étape 5, image 1 de 3 How to Shorten Straps on a Tank Top by Hand: étape 5, image 2 de 3 How to Shorten Straps on a Tank Top by Hand: étape 5, image 3 de 3
    • Draw a line with the fabric pencil on the seam below the strap on either side of the strap.
    • This is where you will sew the strap back in place.
  6. How to Shorten Straps on a Tank Top by Hand: étape 6, image 1 de 2 How to Shorten Straps on a Tank Top by Hand: étape 6, image 2 de 2
    • Use the seam ripper to rip the seams from the back of the strap where it meets the back of the shirt.
  7. How to Shorten Straps on a Tank Top by Hand: étape 7, image 1 de 3 How to Shorten Straps on a Tank Top by Hand: étape 7, image 2 de 3 How to Shorten Straps on a Tank Top by Hand: étape 7, image 3 de 3
    • Turn the top inside out.
    • Match the strap with the lines from Steps 4 and 5.
    • Pin the strap so it stays in place.
  8. How to Shorten Straps on a Tank Top by Hand: étape 8, image 1 de 3 How to Shorten Straps on a Tank Top by Hand: étape 8, image 2 de 3 How to Shorten Straps on a Tank Top by Hand: étape 8, image 3 de 3
    • Use a needle and a thread that has a similar color to the fabric to sew the strap to the seam of the top.
    • Use the white lines from the fabric pencil as a guide.
    • Pierce the needle through the fabric of the top and then pull the needle through the strap.
    • Continue the same process downwards until reaching the end of the seam of the top.
    • Tie a knot after pulling the string.
    • Cut the excess thread.
    • Repeat the step for the opposite side of the strap and the upper side of the strap.
  9. How to Shorten Straps on a Tank Top by Hand: étape 9, image 1 de 1
    • Put the top back on.
    • Make sure the top fits properly. If not, repeat the guide from Step 1.
  10. How to Shorten Straps on a Tank Top by Hand: étape 10, image 1 de 1
    • Use fabric scissors to cut the excess fabric.
    • Repeat all the steps for the other strap.
Ligne d'arrivée
Victoria Reyes
Membre depuis le 10/06/21
181 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 42
30 derniers jours : 267
Total : 9,185
