Aller au contenu principal
Huawei P10 Plus Loudspeaker Replacement
Ce dont vous avez besoin
  1. Huawei P10 Plus Loudspeaker Replacement, Display: étape 1, image 1 de 3 Huawei P10 Plus Loudspeaker Replacement, Display: étape 1, image 2 de 3 Huawei P10 Plus Loudspeaker Replacement, Display: étape 1, image 3 de 3
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Loudspeaker Replacement: étape 2, image 1 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 2, image 2 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 2, image 3 de 3
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Loudspeaker Replacement, Unfasten the screw: étape 3, image 1 de 1
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Loudspeaker Replacement: étape 4, image 1 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 4, image 2 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Tesa 61395 Tape
    $5.99
    J'achète
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  5. Huawei P10 Plus Loudspeaker Replacement, Midframe: étape 5, image 1 de 2 Huawei P10 Plus Loudspeaker Replacement, Midframe: étape 5, image 2 de 2
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
  6. Huawei P10 Plus Loudspeaker Replacement: étape 6, image 1 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 6, image 2 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 6, image 3 de 3
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  7. Huawei P10 Plus Loudspeaker Replacement: étape 7, image 1 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 7, image 2 de 3 Huawei P10 Plus Loudspeaker Replacement: étape 7, image 3 de 3
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  8. Huawei P10 Plus Loudspeaker Replacement, Loudspeaker: étape 8, image 1 de 2 Huawei P10 Plus Loudspeaker Replacement, Loudspeaker: étape 8, image 2 de 2
    • Disconnect the loudspeaker flex cable with a spudger.
    • Use an iOpener to loosen the adhesive beneath the loudspeaker.
  9. Huawei P10 Plus Loudspeaker Replacement: étape 9, image 1 de 2 Huawei P10 Plus Loudspeaker Replacement: étape 9, image 2 de 2
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker.
    • Remove the loudspeaker.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membre depuis le 11/23/16
203 362 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 707
