Aller au contenu principal
Huawei P8 Lite Battery Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
Vidéo d'introduction
  1. Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: étape 1, image 1 de 2 Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    J'achète
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Battery Replacement: étape 2, image 1 de 1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Battery Replacement: étape 3, image 1 de 2 Huawei P8 Lite Battery Replacement: étape 3, image 2 de 2
    Spudger
    $2.99
    J'achète
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Battery Replacement, Replace Battery: étape 4, image 1 de 1
    • Locate adhesive strip underneath the battery and grip with your thumb and forefinger. Slowly pull on the adhesive strip until it's off to release adhesive securing battery.
  5. Huawei P8 Lite Battery Replacement: étape 5, image 1 de 1
    Spudger
    $2.99
    J'achète
    • Insert the Spudger tool underneath the battery multiple times to separate the adhesive securing the battery. Be careful not to bend the battery and lift it from the phone frame.
    • Replace the adhesive and insert the replacement battery into the slot.
To reassemble your device, follow these steps in reverse order.
6 autres ont terminé cette réparation.
Brett Anderson
Membre depuis le 01/15/16
286 Réputation
1 tutoriel rédigé
Équipe
Metro State, Team 1-2, Carpenter Spring 2016 Membre de l'équipe Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 9,152
