Aller au contenu principal
Huawei P9 Plus Battery Replacement
Ce dont vous avez besoin
  1. Huawei P9 Plus Battery Replacement, Rear Case: étape 1, image 1 de 2 Huawei P9 Plus Battery Replacement, Rear Case: étape 1, image 2 de 2
    • First switch off your phone.
    • Remove the SD and SIM card tray.
  2. Huawei P9 Plus Battery Replacement: étape 2, image 1 de 1
    • Remove the two P2 Pentalobe screws on either side of the USB C port.
  3. Huawei P9 Plus Battery Replacement: étape 3, image 1 de 2 Huawei P9 Plus Battery Replacement: étape 3, image 2 de 2
    • Use an iSclack or a suction handle to separate the display unit from the rear case.
    • Do not fully separate the pieces as they are still connected by the fingerprint sensor cable.
  4. Huawei P9 Plus Battery Replacement: étape 4, image 1 de 3 Huawei P9 Plus Battery Replacement: étape 4, image 2 de 3 Huawei P9 Plus Battery Replacement: étape 4, image 3 de 3
    • After separating the rear case flip the other half open to get to the flex connectors.
    • With a spudger unplug the flex connector of the fingerprint sensor and the one of the side buttons.
    • Remove the rear case.
  5. Huawei P9 Plus Battery Replacement, Battery: étape 5, image 1 de 2 Huawei P9 Plus Battery Replacement, Battery: étape 5, image 2 de 2
    • Remove the sticker that sits on top of the left screw above the battery.
    • Remove the three Phillips #00 screws that hold the metal plates in place.
  6. Huawei P9 Plus Battery Replacement: étape 6, image 1 de 2 Huawei P9 Plus Battery Replacement: étape 6, image 2 de 2
    • Both metal plates have little hooks. Use a tweezer to free them and unhinge the plates by carefully moving them upwards.
  7. Huawei P9 Plus Battery Replacement: étape 7, image 1 de 3 Huawei P9 Plus Battery Replacement: étape 7, image 2 de 3 Huawei P9 Plus Battery Replacement: étape 7, image 3 de 3
    • Use a spudger to unplug the screen flex cable.
    • Unplug the motherboard flex cable and the battery flex cable afterwards.
  8. Huawei P9 Plus Battery Replacement: étape 8, image 1 de 2 Huawei P9 Plus Battery Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • The adhesive strips at the top of the battery are less likely to rip if you pull them horizontally in a straight line and not upwards or in any other direction.
    • Use a set of tweezers to unfold the black tab enough to grab with your fingers.
    • Pull the first adhesive strip in a slow and constant movement.
    • Jerking or slackening your grip can cause the adhesive to bunch up and rip.
  9. Huawei P9 Plus Battery Replacement: étape 9, image 1 de 2 Huawei P9 Plus Battery Replacement: étape 9, image 2 de 2
    • Loosen the end of the other adhesive strip with a tweezer and pull it out. If needed use the iOpener again to soften the glue a little.
  10. Huawei P9 Plus Battery Replacement: étape 10, image 1 de 3 Huawei P9 Plus Battery Replacement: étape 10, image 2 de 3 Huawei P9 Plus Battery Replacement: étape 10, image 3 de 3
    Tesa 61395 Tape
    $5.99
    • Use a spudger to slide under the battery.
    • If you managed to pull out the adhesive strips you can easily lift out the battery. Otherwise use the iOpener once more to soften any adhesive leftovers. There are no cables under the battery that can be harmed.
    • Remove the battery.
    • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
To reassemble your device, follow these instructions in reverse order and apply new adhesive strips where necessary.
12 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
229 724 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
19 477 tutoriels rédigés
Un commentaire
Great tutorial, thanks alot!
Lior Nissim - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 47
Total : 17,911
