Aller au contenu principal
Pour réparer ensemble - Je crée un compte
InFocus IN3104 Filter Replacement
Ce dont vous avez besoin
  1. InFocus IN3104 Filter Replacement, Top Cover: étape 1, image 1 de 3 InFocus IN3104 Filter Replacement, Top Cover: étape 1, image 2 de 3 InFocus IN3104 Filter Replacement, Top Cover: étape 1, image 3 de 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Demander à FixBot
    Ajouter un commentaire
  2. InFocus IN3104 Filter Replacement: étape 2, image 1 de 3 InFocus IN3104 Filter Replacement: étape 2, image 2 de 3 InFocus IN3104 Filter Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Demander à FixBot
  3. InFocus IN3104 Filter Replacement, Filter: étape 3, image 1 de 3 InFocus IN3104 Filter Replacement, Filter: étape 3, image 2 de 3 InFocus IN3104 Filter Replacement, Filter: étape 3, image 3 de 3
    • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
    • Once the screw is removed, remove the filter by pulling it straight out.
    Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 21
Total : 588
