Aller au contenu principal
Pour réparer ensemble - Je crée un compte
InFocus LP540 Projector Main Board Replacement
Ce dont vous avez besoin
    1. InFocus LP540 Projector Main Board Replacement, Main Board: étape 1, image 1 de 3 InFocus LP540 Projector Main Board Replacement, Main Board: étape 1, image 2 de 3 InFocus LP540 Projector Main Board Replacement, Main Board: étape 1, image 3 de 3
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      Demander à FixBot
      Ajouter un commentaire
    2. InFocus LP540 Projector Main Board Replacement: étape 2, image 1 de 2 InFocus LP540 Projector Main Board Replacement: étape 2, image 2 de 2
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      Demander à FixBot
    3. InFocus LP540 Projector Main Board Replacement: étape 3, image 1 de 3 InFocus LP540 Projector Main Board Replacement: étape 3, image 2 de 3 InFocus LP540 Projector Main Board Replacement: étape 3, image 3 de 3
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      Demander à FixBot
    4. InFocus LP540 Projector Main Board Replacement: étape 4, image 1 de 2 InFocus LP540 Projector Main Board Replacement: étape 4, image 2 de 2
      • Hold down the release tabs to remove the cables from the white tabs.
      Demander à FixBot
    5. InFocus LP540 Projector Main Board Replacement: étape 5, image 1 de 3 InFocus LP540 Projector Main Board Replacement: étape 5, image 2 de 3 InFocus LP540 Projector Main Board Replacement: étape 5, image 3 de 3
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      Demander à FixBot
    6. InFocus LP540 Projector Main Board Replacement: étape 6, image 1 de 3 InFocus LP540 Projector Main Board Replacement: étape 6, image 2 de 3 InFocus LP540 Projector Main Board Replacement: étape 6, image 3 de 3
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      Demander à FixBot
Jorge L Navarro
Membre depuis le 01/22/14
533 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-17, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 29
Total : 2,659
