Aller au contenu principal
Pour réparer ensemble - Je crée un compte
InFocus Remote Button Pad Replacement
Ce dont vous avez besoin
    1. InFocus Remote Button Pad Replacement, Front Cover: étape 1, image 1 de 2 InFocus Remote Button Pad Replacement, Front Cover: étape 1, image 2 de 2
      • Use your finger to press the tab on the battery cover.
      • Lift the cover up and out.
      Demander à FixBot
      Ajouter un commentaire
    2. InFocus Remote Button Pad Replacement: étape 2, image 1 de 2 InFocus Remote Button Pad Replacement: étape 2, image 2 de 2
      • Use your finger to lift the two AA batteries up and out of the remote.
      Demander à FixBot
    3. InFocus Remote Button Pad Replacement: étape 3, image 1 de 1
      • Remove the three 9mm Phillips #00 screws located on the backside of the remote.
      Demander à FixBot
    4. InFocus Remote Button Pad Replacement: étape 4, image 1 de 2 InFocus Remote Button Pad Replacement: étape 4, image 2 de 2
      • Insert a plastic opening tool into the seam between the black top cover and silver base at the bottom edge of the remote.
      • Carefully pry the top cover up and away from the base.
      Demander à FixBot
    5. InFocus Remote Button Pad Replacement: étape 5, image 1 de 3 InFocus Remote Button Pad Replacement: étape 5, image 2 de 3 InFocus Remote Button Pad Replacement: étape 5, image 3 de 3
      • Insert an opening pick into the seam on side of the remote, even with the InFocus Label.
      • Slide the opening pick along the side of the remote, moving towards the buttons.
      • There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
      Demander à FixBot
    6. InFocus Remote Button Pad Replacement: étape 6, image 1 de 3 InFocus Remote Button Pad Replacement: étape 6, image 2 de 3 InFocus Remote Button Pad Replacement: étape 6, image 3 de 3
      • Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose.
      Demander à FixBot
    7. InFocus Remote Button Pad Replacement: étape 7, image 1 de 2 InFocus Remote Button Pad Replacement: étape 7, image 2 de 2
      • Firmly grasp the cover and lift it away from the remote.
      Demander à FixBot
    1. InFocus Remote Button Pad Replacement, Button Pad: étape 8, image 1 de 2 InFocus Remote Button Pad Replacement, Button Pad: étape 8, image 2 de 2
      • Lift the button pad up and out of the remote.
      Demander à FixBot
Paige Reisman
Membre depuis le 04/07/14
24 175 Réputation
15 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 25
Total : 705
