Aller au contenu principal
Pour réparer ensemble - Je crée un compte
InFocus Screenplay 4805 Lens Replacement
Ce dont vous avez besoin
  1. InFocus Screenplay 4805 Lens Replacement, Top Panel: étape 1, image 1 de 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: étape 1, image 2 de 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: étape 1, image 3 de 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    Demander à FixBot
    Ajouter un commentaire
  2. InFocus Screenplay 4805 Lens Replacement: étape 2, image 1 de 2 InFocus Screenplay 4805 Lens Replacement: étape 2, image 2 de 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
    Demander à FixBot
  3. InFocus Screenplay 4805 Lens Replacement: étape 3, image 1 de 3 InFocus Screenplay 4805 Lens Replacement: étape 3, image 2 de 3 InFocus Screenplay 4805 Lens Replacement: étape 3, image 3 de 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
    Demander à FixBot
  4. InFocus Screenplay 4805 Lens Replacement: étape 4, image 1 de 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
    Demander à FixBot
  5. InFocus Screenplay 4805 Lens Replacement: étape 5, image 1 de 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
    Demander à FixBot
  6. InFocus Screenplay 4805 Lens Replacement, Lens: étape 6, image 1 de 3 InFocus Screenplay 4805 Lens Replacement, Lens: étape 6, image 2 de 3 InFocus Screenplay 4805 Lens Replacement, Lens: étape 6, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
    • Gently pull out the lens.
    Demander à FixBot
To reassemble the device, follow these instructions in reverse order.
Marilyn Urness
Membre depuis le 09/28/17
671 Réputation
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 27
Total : 920
