Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ivation IVWPDC20Y Display Replacement
Ce dont vous avez besoin
    1. Ivation IVWPDC20Y Display Replacement, Display: étape 1, image 1 de 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Demander à FixBot
      Ajouter un commentaire
    2. Ivation IVWPDC20Y Display Replacement: étape 2, image 1 de 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Demander à FixBot
    3. Ivation IVWPDC20Y Display Replacement: étape 3, image 1 de 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
      Demander à FixBot
    4. Ivation IVWPDC20Y Display Replacement: étape 4, image 1 de 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Demander à FixBot
    5. Ivation IVWPDC20Y Display Replacement: étape 5, image 1 de 1
      • Pry off back outer casing using the black spudger or the blue prying tools.
      Demander à FixBot
    6. Ivation IVWPDC20Y Display Replacement: étape 6, image 1 de 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
      Demander à FixBot
    7. Ivation IVWPDC20Y Display Replacement: étape 7, image 1 de 1
      • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
      • Screen and orange tape should slip out as a whole.
      Demander à FixBot
Alex
Membre depuis le 02/08/16
228 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 6-6, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 21
Total : 633
