Aller au contenu principal
Pour réparer ensemble - Je crée un compte
JBL Pulse 3 LED Light Display Replacement
Ce dont vous avez besoin
    1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: étape 1, image 1 de 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Demander à FixBot
      Ajouter un commentaire
    2. JBL Pulse 3 LED Light Display Replacement: étape 2, image 1 de 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Demander à FixBot
    3. JBL Pulse 3 LED Light Display Replacement: étape 3, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 3, image 2 de 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Demander à FixBot
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Demander à FixBot
    1. JBL Pulse 3 LED Light Display Replacement, Outside Casing: étape 5, image 1 de 2 JBL Pulse 3 LED Light Display Replacement, Outside Casing: étape 5, image 2 de 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Demander à FixBot
    2. JBL Pulse 3 LED Light Display Replacement: étape 6, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 6, image 2 de 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Demander à FixBot
    3. JBL Pulse 3 LED Light Display Replacement: étape 7, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 7, image 2 de 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Demander à FixBot
    4. JBL Pulse 3 LED Light Display Replacement: étape 8, image 1 de 1
      • Pull off the top disc of the JBL Pulse 3.
      Demander à FixBot
    5. JBL Pulse 3 LED Light Display Replacement: étape 9, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 9, image 2 de 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Demander à FixBot
    6. JBL Pulse 3 LED Light Display Replacement: étape 10, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 10, image 2 de 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Demander à FixBot
    7. JBL Pulse 3 LED Light Display Replacement: étape 11, image 1 de 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Demander à FixBot
    1. JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 1 de 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 2 de 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: étape 12, image 3 de 3
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      Demander à FixBot
    2. JBL Pulse 3 LED Light Display Replacement: étape 13, image 1 de 2 JBL Pulse 3 LED Light Display Replacement: étape 13, image 2 de 2
      Outil utilisé dans cette étape :
      • Use tweezers to pull the five connections off of the LED light display.
      Demander à FixBot
3 autres ont terminé cette réparation.
Kaitlyn Greenfield
Membre depuis le 09/20/18
1 188 Réputation
6 tutoriels rédigés
4 commentaires de tutoriel
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Réponse Partager
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Réponse Partager
Where to buy the leds?
mj.viana1993 - Réponse Partager
Hello i need an assitance in a LED screen manufacturing
volkanoo - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 45
Total : 4,260
