Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Jabra Elite 85h Bluetooth Module Replacement
Ce dont vous avez besoin
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: étape 1, image 1 de 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: étape 1, image 2 de 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: étape 1, image 3 de 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Demander à FixBot
    Ajouter un commentaire
  2. Jabra Elite 85h Bluetooth Module Replacement: étape 2, image 1 de 3 Jabra Elite 85h Bluetooth Module Replacement: étape 2, image 2 de 3 Jabra Elite 85h Bluetooth Module Replacement: étape 2, image 3 de 3
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
    Demander à FixBot
  3. Jabra Elite 85h Bluetooth Module Replacement: étape 3, image 1 de 3 Jabra Elite 85h Bluetooth Module Replacement: étape 3, image 2 de 3 Jabra Elite 85h Bluetooth Module Replacement: étape 3, image 3 de 3
    • Repeat previous steps on other side.
    Demander à FixBot
  4. Jabra Elite 85h Bluetooth Module Replacement: étape 4, image 1 de 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
    Demander à FixBot
  5. Jabra Elite 85h Bluetooth Module Replacement: étape 5, image 1 de 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    Demander à FixBot
  6. Jabra Elite 85h Bluetooth Module Replacement: étape 6, image 1 de 2 Jabra Elite 85h Bluetooth Module Replacement: étape 6, image 2 de 2
    • Remove the two screws holding the upper and lower circuit boards in place.
    Demander à FixBot
  7. Jabra Elite 85h Bluetooth Module Replacement: étape 7, image 1 de 2 Jabra Elite 85h Bluetooth Module Replacement: étape 7, image 2 de 2
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
    Demander à FixBot
Ryan Callaghan
Membre depuis le 03/13/23
965 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-4, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G4
4 membres
12 tutoriels rédigés
2 commentaires de tutoriel
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Réponse Partager
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 41
Total : 2,554
