Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Jam Voice Battery Replacement
Ce dont vous avez besoin
    1. Jam Voice Battery Replacement, Hard Mesh Cover: étape 1, image 1 de 2 Jam Voice Battery Replacement, Hard Mesh Cover: étape 1, image 2 de 2
      • Insert the plastic opening tool underneath the mesh top.
      • Pry the cover open.
      • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
      Demander à FixBot
      Ajouter un commentaire
    1. Jam Voice Battery Replacement, Motherboard: étape 2, image 1 de 1
      • Remove the four 7mm Phillips screws from the plastic cover.
      Demander à FixBot
    2. Jam Voice Battery Replacement: étape 3, image 1 de 2 Jam Voice Battery Replacement: étape 3, image 2 de 2
      • Remove the four 5mm Phillips screws that hold down the speaker in place.
      • Remove the two 6mm Phillips screws that hold down the plastic casing.
      Demander à FixBot
    3. Jam Voice Battery Replacement: étape 4, image 1 de 1
      Outil utilisé dans cette étape :
      Halberd Spudger
      $2.99
      • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
      • Pull the speaker up and out.
      Demander à FixBot
    4. Jam Voice Battery Replacement: étape 5, image 1 de 3 Jam Voice Battery Replacement: étape 5, image 2 de 3 Jam Voice Battery Replacement: étape 5, image 3 de 3
      • Remove the four 7mm Phillips screws to expose the motherboard.
      Demander à FixBot
    5. Jam Voice Battery Replacement: étape 6, image 1 de 1
      • After removing all of the screws from the plastic cover, remove it by pulling up and out.
      • Be careful not to pull and damage any of the wires.
      Demander à FixBot
    6. Jam Voice Battery Replacement: étape 7, image 1 de 2 Jam Voice Battery Replacement: étape 7, image 2 de 2
      • Remove the three 5mm Phillips screws that hold the motherboard in place.
      • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
      Demander à FixBot
    1. Jam Voice Battery Replacement, Battery: étape 8, image 1 de 3 Jam Voice Battery Replacement, Battery: étape 8, image 2 de 3 Jam Voice Battery Replacement, Battery: étape 8, image 3 de 3
      • Expose the motherboard and battery and place in a position that will be easy to access and work with.
      • Use tweezers to remove the battery's wire from the motherboard at the connection point.
      • The battery's connection point is opposite the speaker's connection point.
      • Pull the battery from the motherboard.
      Demander à FixBot
Hope Bukhamseen
Membre depuis le 04/05/18
298 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 44
Total : 1,091
