Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Jazz HDV178 Camcorder Operating Buttons Replacement
Ce dont vous avez besoin
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Back Cover: étape 1, image 1 de 1
      • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
      • Press down on the grooved plastic with your thumbs.
      • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
      Demander à FixBot
      Ajouter un commentaire
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Battery: étape 2, image 1 de 1
      • Once you have the back cover off, the camcorder should look like this.
      • Look on the battery for a model number to assure that you acquire the correct replacement part.
      • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
      Demander à FixBot
    2. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 3, image 1 de 1
      • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
      Demander à FixBot
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Housing: étape 4, image 1 de 1
      • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
      • This is the bottom of the camcorder near where the wrist strap connects.
      Demander à FixBot
    2. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 5, image 1 de 1
      • Remove the 4.5 mm screw located near the battery slot.
      Demander à FixBot
    3. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 6, image 1 de 1
      • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
      • After the glue is broken, remove the lens cover.
      Demander à FixBot
    4. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 7, image 1 de 1
      • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
      • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
      Demander à FixBot
    5. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 8, image 1 de 3 Jazz HDV178 Camcorder Operating Buttons Replacement: étape 8, image 2 de 3 Jazz HDV178 Camcorder Operating Buttons Replacement: étape 8, image 3 de 3
      • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
      • Remove the silver strip using the same process as the previous step.
      • Remove the two 4 mm screws that were hidden under the cover.
      Demander à FixBot
    6. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 9, image 1 de 3 Jazz HDV178 Camcorder Operating Buttons Replacement: étape 9, image 2 de 3 Jazz HDV178 Camcorder Operating Buttons Replacement: étape 9, image 3 de 3
      • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
      • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
      Demander à FixBot
    7. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 10, image 1 de 1
      • Remove the three combined buttons so they are not misplaced.
      Demander à FixBot
    8. Jazz HDV178 Camcorder Operating Buttons Replacement: étape 11, image 1 de 2 Jazz HDV178 Camcorder Operating Buttons Replacement: étape 11, image 2 de 2
      • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
      • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
      Demander à FixBot
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Operating Buttons: étape 12, image 1 de 1
      Outil utilisé dans cette étape :
      • Use tweezers to remove the rubber button assembly.
      • Blow on the sensors underneath to remove any dust on the sensors.
      • You can also dab a little rubbing alcohol on the sensor pad with a Q-tip and let it dry.
      Demander à FixBot
2 autres ont terminé cette réparation.
Jake Devincenzi
Membre depuis le 01/28/11
170 Réputation
1 tutoriel rédigé
Équipe
James Madison University, Team 1-1, Allen Fall 2012 Membre de l'équipe James Madison University, Team 1-1, Allen Fall 2012
JMU-ALLEN-F12S1G1
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 3,021
