Introduction
Follow this guide to replace a degraded battery in a left Nintendo Joy-Con 2 controller. If you need to replace the battery in a right Joy-Con 2, follow this guide instead.
The Joy-Con 2 uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them.
If your replacement battery doesn't include adhesive, you'll need replacement adhesive or thin, double-sided tape to complete this repair.
Ce dont vous avez besoin
Use a tri‑point Y00 driver to remove the two 3.1 mm‑long black screws on the right edge of the controller.
Insert an opening pick into the gap underneath the bumper button on the left side of the controller, with a point of the pick pointing downwards.
Pry up to slightly lift the plastic strip running across the left edge of the controller.
Slide the opening pick around to the front of the controller.
Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
Pry up on the bottom edge of the plastic strip with slow, steady force.
Repeat this prying action along the length of the strip until it's fully detached.
Remove the two screws on the left edge of the controller:
One 3.1 mm‑long tri‑point Y00 black screw
One 3.0 mm‑long JIS 00 silver screw
Insert an opening pick into the gap between the front and back halves of the controller on its left side.
Slide the pick down the controller to disengage the clips.
Leave the opening pick at the bottom of the controller's left edge, just before its curve.
Hold the controller upside-down.
Insert a point of another opening pick next to the release button at the top of the controller.
Use the opening pick to press the release button through the gap.
While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
Open the back cover.
Firmly grasp the two wires (blue and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
Remove the back cover.
Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
Outil utilisé dans cette étape :iFixit Adhesive Remover$19.99
Insert a flat edge of an opening pick into the gap between the battery and the battery well.
Pry the battery up slowly with steady force to release the adhesive.
If you're using adhesive remover, follow these preparation steps first.
Remove the battery.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
Outil utilisé dans cette étape :Cotton Swabs$4.99
Apply isopropyl alcohol to a cotton swab and wipe any adhesive residue from the frame.
Slide an opening pick or fingernail between the foam and the battery, making sure it's completely below the foam's adhesive.
Carefully peel the foam sticker, including its adhesive, off the old battery. Avoid stretching or tearing the foam.
Apply the foam sticker to the new battery so the edges of the foam are aligned with the edges of the battery.
Outil utilisé dans cette étape :Tesa 61395 Tape$2.95
If your replacement battery came with adhesive pre-installed, peel off any adhesive liners.
Align the battery with its housing. Ensure the battery cable lines up with its channel.
Lower one side of the battery, then the other, into its housing.
Press and hold on the battery for 10 seconds to bond the adhesive.
Hold the release button so its smooth face is perpendicular to the controller.
Insert the release button into its bracket.
Align the battery connector over its socket on the board.
Press down on the connector until it's fully seated.
Align the rumble motor connector to its socket on the bottom edge of the board and push down until it's fully seated to connect it.
Use an opening pick to press and hold the release button.
Place the back cover over the controller body so the release button cutout is slightly below the release button.
Press and slide the back cover up until the cutout for the release button is aligned with the button itself.
Install the two screws on the left edge of the controller:
Align the clips on the plastic strip with their cut-outs on the controller body.
Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
Use a tri‑point Y00 driver to install the two 3.1 mm‑long black screws on the right edge of the controller.
You finished fixing your Joy-Con 2!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
