Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Joy-Con 2 (Right) Joystick Replacement
Ce dont vous avez besoin
  1. Joy-Con 2 (Right) Joystick Replacement, Remove the left edge screws: étape 1, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the left edge screws: étape 1, image 2 de 2
    • Use a tri-point Y00 driver to remove the two 3.1 mm‑long black screws on the left edge of the controller.
  2. Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: étape 2, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: étape 2, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Insert an opening pick into the gap underneath the bumper button on the right side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the right edge of the controller.
    • Slide the opening pick around to the front of the controller.
  3. Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: étape 3, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: étape 3, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: étape 3, image 3 de 3
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
  4. Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: étape 4, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: étape 4, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: étape 4, image 3 de 3
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
  5. Joy-Con 2 (Right) Joystick Replacement: étape 5, image 1 de 1
    • Remove the plastic strip.
  6. Joy-Con 2 (Right) Joystick Replacement, Remove the right edge screws: étape 6, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the right edge screws: étape 6, image 2 de 2
    • Remove the two screws on the right edge of the controller:
    • One 3.1 mm‑long tri-point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
  7. Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: étape 7, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: étape 7, image 2 de 2
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its right side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's right edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
  8. Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: étape 8, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: étape 8, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: étape 8, image 3 de 3
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button towards the top of the controller.
    • Use the opening pick to press the release button through the gap.
  9. Joy-Con 2 (Right) Joystick Replacement, Release the back cover: étape 9, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Release the back cover: étape 9, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Release the back cover: étape 9, image 3 de 3
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
  10. Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: étape 10, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: étape 10, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: étape 10, image 3 de 3
    • Firmly grasp the two wires (yellow and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
  11. Joy-Con 2 (Right) Joystick Replacement, Disconnect the battery: étape 11, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Disconnect the battery: étape 11, image 2 de 2
    • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
  12. Joy-Con 2 (Right) Joystick Replacement, Remove the release button: étape 12, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the release button: étape 12, image 2 de 2
    • Pick up the release button and remove it.
  13. Joy-Con 2 (Right) Joystick Replacement, Remove the trigger: étape 13, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the trigger: étape 13, image 2 de 2
    • If your JIS 00 driver is able to access the screw underneath the trigger button, you may skip this step.
    • Insert an opening pick between the bumper (R) and trigger (ZR) buttons at the top of the controller.
    • Use the opening pick to pry the trigger away from the bumper until it pops off the controller.
    • You can lightly hold the ZR button with your finger to avoid launching it.
  14. Joy-Con 2 (Right) Joystick Replacement, Remove the screws: étape 14, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the screws: étape 14, image 2 de 2
    • Use a JIS 00 driver to remove the five screws securing the midframe:
    • Four 3.9 mm‑long silver screws
    • One 6.2 mm‑long black screw
  15. Joy-Con 2 (Right) Joystick Replacement, Remove the bumper: étape 15, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the bumper: étape 15, image 2 de 2
    • Hold the midframe lightly in place.
    • Pull the bumper (R) button off its mounting pegs and remove it.
    • The midframe will lift slightly when removing this button.
  16. Joy-Con 2 (Right) Joystick Replacement, Remove the bracket: étape 16, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the bracket: étape 16, image 2 de 2
    • Pick up the release button mounting bracket and remove it.
  17. Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: étape 17, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: étape 17, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: étape 17, image 3 de 3
    • Use the back cover to prop up the controller while you work.
    • The buttons on the front of the controller should rest on the back cover's lip to keep it stable.
  18. Joy-Con 2 (Right) Joystick Replacement, Lift the trigger button board: étape 18, image 1 de 1
    • Use a JIS 00 driver to remove the 3.9 mm‑long silver screw securing the trigger button board.
  19. Joy-Con 2 (Right) Joystick Replacement: étape 19, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 19, image 2 de 2
    • Insert the point of a spudger underneath the board, and lift it until it pops up.
  20. Joy-Con 2 (Right) Joystick Replacement, Remove the midframe: étape 20, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the midframe: étape 20, image 2 de 2
    • Pick up and remove the midframe.
  21. Joy-Con 2 (Right) Joystick Replacement, Disconnect the trigger board: étape 21, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Disconnect the trigger board: étape 21, image 2 de 2
    • Use the point of a spudger to flip up the locking flap on the trigger button ZIF connector, located on the controller's board.
  22. Joy-Con 2 (Right) Joystick Replacement: étape 22, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 22, image 2 de 2
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • Remove the trigger button board.
  23. Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: étape 23, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: étape 23, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: étape 23, image 3 de 3
    • Repeat this procedure to disconnect the remaining three ZIF connectors on the controller's board.
  24. Joy-Con 2 (Right) Joystick Replacement, Remove the board screws: étape 24, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the board screws: étape 24, image 2 de 2
    • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
  25. Joy-Con 2 (Right) Joystick Replacement, Lift the board: étape 25, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Lift the board: étape 25, image 2 de 2
    • Insert the point of a spudger between the board and the controller, near the battery connector socket.
    • Pry up on the board enough to grasp its edge with your fingertips.
  26. Joy-Con 2 (Right) Joystick Replacement, Remove the board: étape 26, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the board: étape 26, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Remove the board: étape 26, image 3 de 3
    • Lift the board by its outer edges to a roughly 45-degree angle, so it's no longer being blocked by the joystick assembly.
    • Make sure the black tape is fully lifted off the back of the joystick module. Work slowly to avoid tearing the tape.
    • Remove the board.
  27. Joy-Con 2 (Right) Joystick Replacement, Remove the joystick: étape 27, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Remove the joystick: étape 27, image 2 de 2
    • Use a JIS 00 driver to remove the two 3.9 mm‑long silver screws securing the joystick.
  28. Joy-Con 2 (Right) Joystick Replacement: étape 28, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 28, image 2 de 2
    • Pick up and remove the joystick.
  29. Joy-Con 2 (Right) Joystick Replacement, Disassembly complete: étape 29, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  30. Joy-Con 2 (Right) Joystick Replacement, Install the joystick: étape 30, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the joystick: étape 30, image 2 de 2
    • Align the cut-out in the joystick's plastic frame with its peg on the controller.
    • Set the joystick in the controller. Gently wiggle the joystick to ensure it's fully seated.
  31. Joy-Con 2 (Right) Joystick Replacement: étape 31, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 31, image 2 de 2
    • Use a JIS 00 driver to install the two 3.9 mm‑long silver screws securing the joystick.
  32. Joy-Con 2 (Right) Joystick Replacement, Install the board: étape 32, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the board: étape 32, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the board: étape 32, image 3 de 3
    • Lower the board's flat side into the controller at an angle.
    • Use a spudger to bend the joystick's ribbon cable so it's perpendicular with the joystick.
    • Lower the board so the joystick's ribbon cable routes through the joystick cut-out in the board. Ensure the board is sitting underneath the locking tab on the frame.
  33. Joy-Con 2 (Right) Joystick Replacement: étape 33, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 33, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 33, image 3 de 3
    • Push the board towards the controller's inner edge (the side with the shoulder buttons) to prevent it from colliding with the joystick module.
    • Lower the board into the frame.
    • Use your finger or the flat end of a spudger to press the black tape onto the back of the joystick module.
  34. Joy-Con 2 (Right) Joystick Replacement: étape 34, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 34, image 2 de 2
    • Use a JIS 00 driver to install the five 3.1 mm‑long black screws securing the board to the controller.
  35. Joy-Con 2 (Right) Joystick Replacement, Connect the cables: étape 35, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the cables: étape 35, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the cables: étape 35, image 3 de 3
    • Make sure the locking flap is flipped up on the joystick cable ZIF connector.
    • Insert the joystick ribbon cable into its ZIF connector until it's fully seated.
    • The brown portion of the cable should end at the golden line on the board.
    • Use your finger or a spudger to flip the locking flap down to secure the cable.
  36. Joy-Con 2 (Right) Joystick Replacement: étape 36, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 36, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 36, image 3 de 3
    • Make sure the locking flap is flipped up on the Joy-Con connector cable ZIF connector.
    • Insert the Joy-Con connector ribbon cable into its ZIF connector until it's fully seated.
  37. Joy-Con 2 (Right) Joystick Replacement: étape 37, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 37, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 37, image 3 de 3
    • Repeat this procedure for the shoulder button ZIF connector. The cable is fully seated when its brown "wings" are in their slots on both sides of the connector.
    • This connector can be tricky—you may need to hold the flap open, or hold the cable in place when closing the flap.
  38. Joy-Con 2 (Right) Joystick Replacement, Connect the trigger button board: étape 38, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the trigger button board: étape 38, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the trigger button board: étape 38, image 3 de 3
    • Make sure the locking flap is flipped up on the trigger cable's ZIF connector.
    • Position the trigger button board so its ribbon cable is aligned with its ZIF connector on the board.
    • Use tweezers or your fingers to gently slide the ribbon cable into its ZIF connector.
    • Flip the locking flap down to secure the cable.
  39. Joy-Con 2 (Right) Joystick Replacement, Install the midframe: étape 39, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the midframe: étape 39, image 2 de 2
    • Align the midframe with its screw holes on the outer edge of the controller and set it into place.
  40. Joy-Con 2 (Right) Joystick Replacement, Install the trigger button board: étape 40, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the trigger button board: étape 40, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the trigger button board: étape 40, image 3 de 3
    • Use tweezers or your fingers to set the bottom edge of the trigger button board underneath its tab on the midframe.
    • Press the board into place so the black peg on the midframe protrudes through the hole on the bottom corner of the board.
  41. Joy-Con 2 (Right) Joystick Replacement: étape 41, image 1 de 1
    • Use a JIS 00 driver to install the 3.9 mm‑long silver screw securing the trigger button board.
  42. Joy-Con 2 (Right) Joystick Replacement, Install the bumper: étape 42, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the bumper: étape 42, image 2 de 2
    • Align the two springs on the bumper with their two posts on the midframe, and press it into place.
    • The bumper is held in place by the front shell of the controller. If it falls out, ensure it is fully seated in the shell.
  43. Joy-Con 2 (Right) Joystick Replacement, Install the midframe screws: étape 43, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the midframe screws: étape 43, image 2 de 2
    • Use a JIS 00 driver to install the three 3.9 mm‑long silver screws securing the midframe.
  44. Joy-Con 2 (Right) Joystick Replacement, Install the bracket: étape 44, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the bracket: étape 44, image 2 de 2
    • Align the release button mounting bracket with its screw holes and press it in the frame so it snaps into place.
    • The corner with the protruding square should be facing the battery.
  45. Joy-Con 2 (Right) Joystick Replacement: étape 45, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 45, image 2 de 2
    • Use a JIS 00 driver to install the two screws securing the release button bracket.
    • One 3.9 mm‑long silver screw
  46. Joy-Con 2 (Right) Joystick Replacement, Install the buttons: étape 46, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the buttons: étape 46, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the buttons: étape 46, image 3 de 3
    • If you left the trigger button in place, skip this step.
    • Align the trigger button with the top of the controller, with the "ZR" engraving facing out.
    • Set the trigger button onto its metal spring. Ensure the legs of the spring are seated properly in their channels on the midframe.
    • Press firmly on the trigger button to snap it into place.
    • Check that the metal stabilizer didn't fall out of position. If it did, remove the trigger, place it back into position, and try again.
  47. Joy-Con 2 (Right) Joystick Replacement: étape 47, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 47, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement: étape 47, image 3 de 3
    • Hold the release button so its smooth face is perpendicular to the controller.
    • Insert the release button into its bracket.
    • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
  48. Joy-Con 2 (Right) Joystick Replacement, Connect the battery: étape 48, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the battery: étape 48, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the battery: étape 48, image 3 de 3
    • Align the battery connector with its socket on the board.
    • Press down on the connector until it's fully seated.
  49. Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: étape 49, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: étape 49, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: étape 49, image 3 de 3
    • Align the rumble motor connector to its socket on the bottom edge of the board, and push down until it's fully seated to connect it.
  50. Joy-Con 2 (Right) Joystick Replacement, Install the back cover: étape 50, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the back cover: étape 50, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the back cover: étape 50, image 3 de 3
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cut-out for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (yellow & white) are fully within the frame.
  51. Joy-Con 2 (Right) Joystick Replacement: étape 51, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement: étape 51, image 2 de 2
    • Remove the opening pick.
  52. Joy-Con 2 (Right) Joystick Replacement, Install the right edge screws: étape 52, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the right edge screws: étape 52, image 2 de 2
    • Install the two screws on the right edge of the controller:
  53. Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: étape 53, image 1 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: étape 53, image 2 de 3 Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: étape 53, image 3 de 3
    • Align the clips on the plastic strip with their cut-outs on the right edge of the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
  54. Joy-Con 2 (Right) Joystick Replacement, Install the left edge screws: étape 54, image 1 de 2 Joy-Con 2 (Right) Joystick Replacement, Install the left edge screws: étape 54, image 2 de 2
    • Use a tri-point Y00 driver to install the two 3.1 mm‑long black screws on the left edge of the controller.
You finished fixing your Joy-Con 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
6 autres ont terminé cette réparation.
Nick Schultz
Membre depuis le 03/24/24
52 907 Réputation
300 tutoriels rédigés
2 commentaires de tutoriel
Hello Reader!
I recently broke my right Nintendo Switch 2 joy-con when it fell off of my bed, and the joystick stem just snapped completely off. I thought all hope was lost, but then I found this guide and bought a repair kit (with proper screwdrivers, pliers, sticks, and smudger; can literally get it off of Amazon, if not from this website).
The steps were super thorough, and the pictures were amazingly accurate. I am a 19-year-old with no mechanical or technological experience, yet I was able to completely repair my joy-con in around an hour (maybe less), and now I don't have to buy new ones!
Please follow this guide if you need to fix your joy-con!! It works!!
Josh Driver - Réponse Partager
Thanks Nick. Great guide. I had the same issue as Josh above and was able to swap out the joystick rather than replace the whole joycon.
Sam - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 40
7 derniers jours : 255
30 derniers jours : 1,148
Total : 8,990
