Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kindle 7th Generation Battery Replacement
Ce dont vous avez besoin
  1. Kindle 7th Generation Battery Replacement, Front Panel: étape 1, image 1 de 2 Kindle 7th Generation Battery Replacement, Front Panel: étape 1, image 2 de 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
    Demander à FixBot
    Ajouter un commentaire
  2. Kindle 7th Generation Battery Replacement: étape 2, image 1 de 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
    Demander à FixBot
  3. Kindle 7th Generation Battery Replacement, Back Panel: étape 3, image 1 de 2 Kindle 7th Generation Battery Replacement, Back Panel: étape 3, image 2 de 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
    Demander à FixBot
  4. Kindle 7th Generation Battery Replacement: étape 4, image 1 de 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
    Demander à FixBot
  5. Kindle 7th Generation Battery Replacement, Battery: étape 5, image 1 de 1
    • Flip the Kindle over, exposing the battery and motherboard.
    Demander à FixBot
  6. Kindle 7th Generation Battery Replacement: étape 6, image 1 de 2 Kindle 7th Generation Battery Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
    • Gently slide the cord from the motherboard connection.
    Demander à FixBot
  7. Kindle 7th Generation Battery Replacement: étape 7, image 1 de 3 Kindle 7th Generation Battery Replacement: étape 7, image 2 de 3 Kindle 7th Generation Battery Replacement: étape 7, image 3 de 3
    • Use the plastic opening tool to pry the battery from the backside of the screen.
    • Set the battery aside.
    • The battery has excessive adhesive so this may take some extra effort. See picture of battery deformed by prying tool during removal.
    • If replacing your battery, safely dispose of your damaged battery and use adhesive to insert the new battery.
    Demander à FixBot
35 autres ont terminé cette réparation.
Abby Roulier
Membre depuis le 02/08/15
1 167 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-28, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 membres
26 tutoriels rédigés
27 commentaires de tutoriel
Where can I purchase the battery?
Boon - Réponse Partager
@boonspot right here on this site: Kindle 7 (2014) Battery
Nathan T - Réponse Partager
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Joshua - Réponse Partager
My old battery got seriously deformed during removal, but didn't puncture or tear. I added a picture to the guide, so that hopefully the next person is not as alarmed as I was :)
Where do I get a new battery from please?
Tracy Armstrong - Réponse Partager
Nombre de vues :
Dernières 24 heures : 27
7 derniers jours : 192
30 derniers jours : 960
Total : 65,968
