Aller au contenu principal
Pour réparer ensemble - Je crée un compte
KitchenAid Professional 600 Speed Selector Replacement
Ce dont vous avez besoin
  1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: étape 1, image 1 de 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Demander à FixBot
    Ajouter un commentaire
  2. KitchenAid Professional 600 Speed Selector Replacement: étape 2, image 1 de 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
    Demander à FixBot
  3. KitchenAid Professional 600 Speed Selector Replacement: étape 3, image 1 de 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
    Demander à FixBot
  4. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: étape 4, image 1 de 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
    Demander à FixBot
  5. KitchenAid Professional 600 Speed Selector Replacement: étape 5, image 1 de 3 KitchenAid Professional 600 Speed Selector Replacement: étape 5, image 2 de 3 KitchenAid Professional 600 Speed Selector Replacement: étape 5, image 3 de 3
    • Unplug the cords attaching the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
    Demander à FixBot
  6. KitchenAid Professional 600 Speed Selector Replacement: étape 6, image 1 de 1
    • Pull out the Selector Switch.
    Demander à FixBot
4 autres ont terminé cette réparation.
Tallon Dotinga
Membre depuis le 04/11/16
487 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 25-4, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 membres
27 tutoriels rédigés
8 commentaires de tutoriel
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - Réponse Partager
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - Réponse Partager
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson - Réponse Partager
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - Réponse Partager
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - Réponse Partager
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 32
30 derniers jours : 132
Total : 14,701
