Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG BP220 Disc Drive Replacement
Ce dont vous avez besoin
    1. LG BP220 Disc Drive Replacement, Disc Drive: étape 1, image 1 de 2 LG BP220 Disc Drive Replacement, Disc Drive: étape 1, image 2 de 2
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      Demander à FixBot
      Ajouter un commentaire
    2. LG BP220 Disc Drive Replacement: étape 2, image 1 de 1
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      Demander à FixBot
    3. LG BP220 Disc Drive Replacement: étape 3, image 1 de 3 LG BP220 Disc Drive Replacement: étape 3, image 2 de 3 LG BP220 Disc Drive Replacement: étape 3, image 3 de 3
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      Demander à FixBot
    4. LG BP220 Disc Drive Replacement: étape 4, image 1 de 2 LG BP220 Disc Drive Replacement: étape 4, image 2 de 2
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive and pull out to remove.
      Demander à FixBot
6 autres ont terminé cette réparation.
Bart Quicho
Membre depuis le 01/13/15
520 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team 1-1, Rose Winter 2015 Membre de l'équipe UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 65
Total : 9,589
