Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG G Watch R Power Button
Ce dont vous avez besoin
    1. LG G Watch R Power Button, Back Case: étape 1, image 1 de 2 LG G Watch R Power Button, Back Case: étape 1, image 2 de 2
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      Demander à FixBot
      Ajouter un commentaire
    2. LG G Watch R Power Button: étape 2, image 1 de 1
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      Demander à FixBot
    3. LG G Watch R Power Button: étape 3, image 1 de 1
      • Remove the back case.
      Demander à FixBot
    1. LG G Watch R Power Button, Motherboard: étape 4, image 1 de 2 LG G Watch R Power Button, Motherboard: étape 4, image 2 de 2
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      Demander à FixBot
    2. LG G Watch R Power Button: étape 5, image 1 de 2 LG G Watch R Power Button: étape 5, image 2 de 2
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      Demander à FixBot
    3. LG G Watch R Power Button: étape 6, image 1 de 1
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      Demander à FixBot
    1. LG G Watch R Power Button, Battery Replacement: étape 7, image 1 de 1
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      Demander à FixBot
    1. LG G Watch R Power Button, Battery Housing Replacement: étape 8, image 1 de 2 LG G Watch R Power Button, Battery Housing Replacement: étape 8, image 2 de 2
      • Pry the battery housing from the top right corner using a spudger.
      • Once loosened, remove the battery housing.
      Demander à FixBot
    1. LG G Watch R Power Button, Power Button: étape 9, image 1 de 3 LG G Watch R Power Button, Power Button: étape 9, image 2 de 3 LG G Watch R Power Button, Power Button: étape 9, image 3 de 3
      Outil utilisé dans cette étape :
      • On the power button, locate a small grey washer on the interior side of the watch.
      • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
      Demander à FixBot
7 autres ont terminé cette réparation.
Westley Courchene
Membre depuis le 01/13/15
3 410 Réputation
14 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 membres
24 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 58
Total : 3,175
