Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Intuition Screen Protector Replacement
Ce dont vous avez besoin
  1. LG Intuition Screen Protector Replacement, Battery: étape 1, image 1 de 1
    • Turn the device so the two bottom screws are shown.
    Demander à FixBot
    Ajouter un commentaire
  2. LG Intuition Screen Protector Replacement: étape 2, image 1 de 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    Demander à FixBot
  3. LG Intuition Screen Protector Replacement: étape 3, image 1 de 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    Demander à FixBot
  4. LG Intuition Screen Protector Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    Demander à FixBot
  5. LG Intuition Screen Protector Replacement: étape 5, image 1 de 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    Demander à FixBot
  6. LG Intuition Screen Protector Replacement: étape 6, image 1 de 2 LG Intuition Screen Protector Replacement: étape 6, image 2 de 2
    • Gently raise the battery from its compartment.
    Demander à FixBot
  7. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: étape 7, image 1 de 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    Demander à FixBot
  8. LG Intuition Screen Protector Replacement: étape 8, image 1 de 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    Demander à FixBot
  9. LG Intuition Screen Protector Replacement, Camera: étape 9, image 1 de 1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    Demander à FixBot
  10. LG Intuition Screen Protector Replacement: étape 10, image 1 de 1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    Demander à FixBot
  11. LG Intuition Screen Protector Replacement, Volume Buttons: étape 11, image 1 de 2 LG Intuition Screen Protector Replacement, Volume Buttons: étape 11, image 2 de 2
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    Demander à FixBot
  12. LG Intuition Screen Protector Replacement, Screen Protector: étape 12, image 1 de 2 LG Intuition Screen Protector Replacement, Screen Protector: étape 12, image 2 de 2
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    Demander à FixBot
  13. LG Intuition Screen Protector Replacement: étape 13, image 1 de 2 LG Intuition Screen Protector Replacement: étape 13, image 2 de 2
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    Demander à FixBot
  14. LG Intuition Screen Protector Replacement: étape 14, image 1 de 1
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    Demander à FixBot
  15. LG Intuition Screen Protector Replacement: étape 15, image 1 de 2 LG Intuition Screen Protector Replacement: étape 15, image 2 de 2
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    Demander à FixBot
  16. LG Intuition Screen Protector Replacement: étape 16, image 1 de 1
    • Carefully pull the ribbon cable upward and away from the front screen display.
    Demander à FixBot
  17. LG Intuition Screen Protector Replacement: étape 17, image 1 de 1
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    Demander à FixBot
  18. LG Intuition Screen Protector Replacement: étape 18, image 1 de 2 LG Intuition Screen Protector Replacement: étape 18, image 2 de 2
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    Demander à FixBot
Thomas Morrissey
Membre depuis le 10/25/18
616 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 458
