Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Optimus F60 Front Camera Replacement
Ce dont vous avez besoin
  1. LG Optimus F60 Front Camera Replacement, Battery: étape 1, image 1 de 3 LG Optimus F60 Front Camera Replacement, Battery: étape 1, image 2 de 3 LG Optimus F60 Front Camera Replacement, Battery: étape 1, image 3 de 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
    Demander à FixBot
    Ajouter un commentaire
  2. LG Optimus F60 Front Camera Replacement: étape 2, image 1 de 3 LG Optimus F60 Front Camera Replacement: étape 2, image 2 de 3 LG Optimus F60 Front Camera Replacement: étape 2, image 3 de 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
    Demander à FixBot
  3. LG Optimus F60 Front Camera Replacement, Front Camera: étape 3, image 1 de 2 LG Optimus F60 Front Camera Replacement, Front Camera: étape 3, image 2 de 2
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
    Demander à FixBot
  4. LG Optimus F60 Front Camera Replacement: étape 4, image 1 de 2 LG Optimus F60 Front Camera Replacement: étape 4, image 2 de 2
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
    Demander à FixBot
  5. LG Optimus F60 Front Camera Replacement: étape 5, image 1 de 3 LG Optimus F60 Front Camera Replacement: étape 5, image 2 de 3 LG Optimus F60 Front Camera Replacement: étape 5, image 3 de 3
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
    Demander à FixBot
  6. LG Optimus F60 Front Camera Replacement: étape 6, image 1 de 3 LG Optimus F60 Front Camera Replacement: étape 6, image 2 de 3 LG Optimus F60 Front Camera Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
    Demander à FixBot
  7. LG Optimus F60 Front Camera Replacement: étape 7, image 1 de 3 LG Optimus F60 Front Camera Replacement: étape 7, image 2 de 3 LG Optimus F60 Front Camera Replacement: étape 7, image 3 de 3
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
    Demander à FixBot
Austin Johnson
Membre depuis le 04/09/18
171 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 476
