Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Optimus G Pro Midframe Replacement
Ce dont vous avez besoin
  1. LG Optimus G Pro Midframe Replacement, Remove Back Cover.: étape 1, image 1 de 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
    Demander à FixBot
    Ajouter un commentaire
  2. LG Optimus G Pro Midframe Replacement, Remove the Battery.: étape 2, image 1 de 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
    Demander à FixBot
  3. LG Optimus G Pro Midframe Replacement, Screw Removal: étape 3, image 1 de 2 LG Optimus G Pro Midframe Replacement, Screw Removal: étape 3, image 2 de 2
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
    Demander à FixBot
  4. LG Optimus G Pro Midframe Replacement, Remove Cover: étape 4, image 1 de 1
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
    Demander à FixBot
  5. LG Optimus G Pro Midframe Replacement, Completion: étape 5, image 1 de 1
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
    Demander à FixBot
3 autres ont terminé cette réparation.
Wesley Pate
Membre depuis le 09/25/14
1 641 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 15-5, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 membres
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 25
Total : 2,300
