Aller au contenu principal
Lenovo 100s Chromebook-11IBY Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 3, image 1 de 2 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 3, image 2 de 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 4, image 1 de 2 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 4, image 2 de 2
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 5, image 1 de 1
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 6, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 7, image 1 de 1
    • Remove the battery.
  8. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: étape 8, image 1 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: étape 8, image 2 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: étape 8, image 3 de 3
    • Using the black nylon spudger, lift up the grey bar of the ZIF connector attached to the motherboard located in the bottom right corner.
    • Pull out the ribbon cable connecting the motherboard to the daughterboard.
  9. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 9, image 1 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 9, image 2 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 9, image 3 de 3
    • Use the spudger to coax the sliding speaker cables toward you, out of the motherboard attachments.
  10. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 10, image 1 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 10, image 2 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 10, image 3 de 3
    • Use the flat end of the spudger to pop up the display cable connector from the motherboard.
  11. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 11, image 1 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 11, image 2 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 11, image 3 de 3
    • Pry up the coaxial antenna cables from the wifi card with the spudger.
  12. Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 12, image 1 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 12, image 2 de 3 Lenovo 100s Chromebook-11IBY Motherboard Replacement: étape 12, image 3 de 3
    • Use your Phillips #0 screwdriver to remove six 3.7mm screws from the motherboard.
    • Use the same Phillips #0 screwdriver to remove one 3.2mm screw from the wireless card.
    • Wiggle the motherboard gently out from the case. It should come out towards you and slightly to the right.
Sarah Westberg
Membre depuis le 03/11/19
23 134 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 867
