Introduction
If your laptop will not start up or stay charged you may need to replace the battery. It is not a difficult project and the hardest part will be prying the back piece off.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Shut down and unplug your device before beginning.
Ce dont vous avez besoin
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Remove the four 4 mm Phillips #00 screws securing the battery.
Thanks for the catch! I’ve corrected the step.
11 autres ont terminé cette réparation.
3 commentaires
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
