Aller au contenu principal
Lenovo ThinkPad T460s Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    Make sure to pull only the white part. I had some difficulty disconnecting mine and got confused, thinking I was doing the wrong thing.
    Michael Wu - Réponse
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 3 de 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
    My replacement battery didn’t come with a replacement black tape tab.
    Same here - I just used the one from the old battery
    Martijn Graumans -
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 3 de 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
2 autres ont terminé cette réparation.
2 commentaires
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - Réponse
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 58
Total : 3,523
