Aller au contenu principal
Lenovo ThinkPad T460s Wi-Fi Card Replacement
kewei xia
kewei xia et 4 autres contributeurs
Dernière mise à jour le March 21, 2024
10 minutes
Facile
A besoin de meilleures images
If your Lenovo Thinkpad T460s(all modes) is not stably connecting to the internet i.e. weak signals, or even unable to use the internet, use this guide to replace the WIFI module.
The WIFI module connects the laptop to the internet. A faulty WIFI module leads to weak signals or no signals at all.
Before using this guide, check your network status, make sure the connection problem does not come from your router.
Before you begin, please carefully check your laptop completely power off and has no connection with external power source.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    Make sure to pull only the white part. I had some difficulty disconnecting mine and got confused, thinking I was doing the wrong thing.
    Michael Wu - Réponse
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: étape 4, image 3 de 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
    My replacement battery didn’t come with a replacement black tape tab.
    Same here - I just used the one from the old battery
    Martijn Graumans -
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 3 de 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
2 autres ont terminé cette réparation.
2 commentaires de tutoriel
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - Réponse
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 35
Total : 3,543
