Aller au contenu principal
Lenovo ThinkPad T480 CMOS Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480 CMOS Battery Replacement, External Battery: étape 1, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement, External Battery: étape 1, image 2 de 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 CMOS Battery Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 2, image 3 de 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 CMOS Battery Replacement, Back Cover: étape 3, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement, Back Cover: étape 3, image 2 de 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 CMOS Battery Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 4, image 3 de 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 CMOS Battery Replacement, Internal Battery: étape 5, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement, Internal Battery: étape 5, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 CMOS Battery Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 6, image 3 de 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 CMOS Battery Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 7, image 2 de 2
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
  8. Lenovo ThinkPad T480 CMOS Battery Replacement, CMOS Battery: étape 8, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement, CMOS Battery: étape 8, image 2 de 2
    • Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
    • This connector may be very difficult to remove and is easily damaged. Be careful that you don't damage the port when removing the coin cell battery connector.
  9. Lenovo ThinkPad T480 CMOS Battery Replacement: étape 9, image 1 de 2 Lenovo ThinkPad T480 CMOS Battery Replacement: étape 9, image 2 de 2
    • Using the black nylon spudger, pry the coin cell battery off of the motherboard.
    • The coin cell battery is stuck to the board with a light adhesive.
Sarah Westberg
Membre depuis le 03/11/19
29 606 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 540 tutoriels rédigés
Un commentaire
good documentation easy to follow top woman
charles akister - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 18
7 derniers jours : 83
30 derniers jours : 385
Total : 9,577
