Aller au contenu principal
Lenovo ThinkPad T480s Hall Sensor Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: étape 4, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: étape 4, image 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 5, image 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: étape 6, image 3 de 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 7, image 2 de 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: étape 8, image 3 de 3
    • Remove the sensor from the system.
Sarah Westberg
Membre depuis le 03/11/19
24 106 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 895 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 24
30 derniers jours : 117
Total : 2,574
