Introduction
This guide will show you how to replace the Wi-Fi card in a Lenovo ThinkPad T480s laptop.
A Wi-Fi card, also known as a WLAN card, enables the laptop to connect to a wireless network. If you cannot connect your laptop to Wi-Fi, or if you are experiencing intermittent connectivity, you may have a faulty Wi-Fi card. Be sure to rule out other connectivity issues listed here before replacing your Wi-Fi card.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Ce dont vous avez besoin
Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
Un commentaire
Hi, thanks a lot the helpful guide. I have just replaced the WiFi card in my Lenovo T480s with a Intel AX210NGW. My laptop won't boot up. Even when I plug the power adapter into the laptop, the status indicator does not light up. I have removed the WiFi card and tried to power it on without it but no luck. I put back the one that was in before still no luck. I'm stuck, what can I do? Did some power component get disturbed or something? I'd appreciate any help. Thank you.
