Aller au contenu principal
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: étape 1, image 1 de 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: étape 1, image 2 de 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: étape 2, image 1 de 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: étape 3, image 1 de 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: étape 5, image 1 de 1
    • Lift the battery out of the frame and remove it from the device.
4 autres ont terminé cette réparation.
Beckham Richmond
Membre depuis le 02/10/20
467 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G3, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 membres
8 tutoriels rédigés
2 commentaires
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Réponse
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 67
30 derniers jours : 243
Total : 12,166
