Aller au contenu principal
Lenovo ThinkPad x120e LCD Screen Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad x120e LCD Screen Replacement, Battery: étape 1, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: étape 2, image 1 de 3 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: étape 2, image 2 de 3 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: étape 3, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e LCD Screen Replacement: étape 4, image 1 de 3 Lenovo ThinkPad x120e LCD Screen Replacement: étape 4, image 2 de 3 Lenovo ThinkPad x120e LCD Screen Replacement: étape 4, image 3 de 3
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e LCD Screen Replacement: étape 5, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
  6. Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: étape 6, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: étape 6, image 2 de 2
    • Remove the screw covers that are located on both sides of the display using a spudger.
    • Start from the corners of the screw covers to remove it more easily.
  7. Lenovo ThinkPad x120e LCD Screen Replacement: étape 7, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the two 4 mm screws.
  8. Lenovo ThinkPad x120e LCD Screen Replacement: étape 8, image 1 de 1
    • Pry open the frame of the laptop screen using a spudger.
    • Do not try to pry it open from the inside edge of the frame. You may accidentaly damage the screen.
  9. Lenovo ThinkPad x120e LCD Screen Replacement: étape 9, image 1 de 1
    • Using the Phillips #1 screwdriver, remove six screws securing the screen to the device.
  10. Lenovo ThinkPad x120e LCD Screen Replacement: étape 10, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement: étape 10, image 2 de 2
    • Lift up the screen from the top. You should now notice the metal frame.
    • Using the same Phillips #1 screwdriver, remove four screws, two on each edge of the metal frame.
    • The second picture is rotated 90 degrees.
  11. Lenovo ThinkPad x120e LCD Screen Replacement: étape 11, image 1 de 1
    • Remove the connector on top of the webcam by simply pulling it out.
  12. Lenovo ThinkPad x120e LCD Screen Replacement: étape 12, image 1 de 2 Lenovo ThinkPad x120e LCD Screen Replacement: étape 12, image 2 de 2
    • Flip the screen over.
    • Peel the black tape first, then peel the gray tape down to the base of the screen.
  13. Lenovo ThinkPad x120e LCD Screen Replacement: étape 13, image 1 de 1
    • At the base of the screen, there is a transparent tape holding a connector. Peel the tape off.
  14. Lenovo ThinkPad x120e LCD Screen Replacement: étape 14, image 1 de 1
    • Remove the connector underneath where the tape was using a spudger tool.
    • Pull out the connector.
    • Make sure to not damage any of the wires.
  15. Lenovo ThinkPad x120e LCD Screen Replacement: étape 15, image 1 de 1
    • Remove the gray tape fully.
    • Flip over the device, and remove the LCD screen fully.
Jacob Fronzaglia
Membre depuis le 10/25/21
787 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 25
Total : 305
