Aller au contenu principal
Lenovo V14-IIL Display Assembly Replacement
Ce dont vous avez besoin
  1. Lenovo V14-IIL Display Assembly Replacement, Back Panel: étape 1, image 1 de 2 Lenovo V14-IIL Display Assembly Replacement, Back Panel: étape 1, image 2 de 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Display Assembly Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Display Assembly Replacement: étape 3, image 1 de 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Display Assembly Replacement, Display Assembly: étape 4, image 1 de 2 Lenovo V14-IIL Display Assembly Replacement, Display Assembly: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Display Assembly Replacement: étape 5, image 1 de 1
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Display Assembly Replacement: étape 6, image 1 de 2 Lenovo V14-IIL Display Assembly Replacement: étape 6, image 2 de 2
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Display Assembly Replacement: étape 7, image 1 de 1
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
Kristen Gismondi
Membre depuis le 11/12/14
92 197 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
19 475 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 65
