Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga C930-13IKB Battery Replacement
Ce dont vous avez besoin
    1. Lenovo Yoga C930-13IKB Battery Replacement, Back Cover: étape 1, image 1 de 1
      • Flip the device over so that the underside is facing up.
      • Remove the six 3.5 mm T5 Torx screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo Yoga C930-13IKB Battery Replacement: étape 2, image 1 de 2 Lenovo Yoga C930-13IKB Battery Replacement: étape 2, image 2 de 2
      • Pry off the back cover using the plastic opening tool.
      • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
      • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
      • Do not use a metal tool when working with your device.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Battery Replacement: étape 3, image 1 de 2 Lenovo Yoga C930-13IKB Battery Replacement: étape 3, image 2 de 2
      • Carefully lift the cover off with your hands.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo Yoga C930-13IKB Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo Yoga C930-13IKB Battery Replacement, Battery: étape 4, image 3 de 3
      • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
      • Use the spudger for assistance.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Battery Replacement: étape 5, image 1 de 1
      • Unscrew the four 3mm screws with a Phillips screwdriver.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Battery Replacement: étape 6, image 1 de 2 Lenovo Yoga C930-13IKB Battery Replacement: étape 6, image 2 de 2
      • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
      • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
      • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
      • Repeat the procedure for the second strip on the opposite side of the battery.
      • Be careful not to bend the battery. Breaking the battery is dangerous.
      • Remove the battery with your hands.
      Demander à FixBot
24 autres ont terminé cette réparation.
Hanna Lazkani
Membre depuis le 01/23/20
890 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S19-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 membres
69 tutoriels rédigés
16 commentaires de tutoriel
One little addition: After removing the bottom cover of the computer, there are two little clear plastic tapes, one on each side of the battery, that you should peel free before starting to lift the battery out. One of those tapes is shown in this photo, just to the right of the icon that resembles a figure eight: https://d3nevzfk7ii3be.cloudfront.net/ig... Those clear tapes are attached to the black plastic strips beneath the battery, that you want to try to leave in place. If you don’t peel back the clear tape tabs, they will increase the likelihood of pulling up those black plastic strips when you start to lift the battery up. My original battery was adhered quite strongly to those plastic strips, and it took a fair bit of work to “dissect” them from the battery using a straight plastic tool that had an end like a regular screwdriver. I did peel those strips up off the computer a bit, but they stuck back down after I separated them from the battery. Thanks for the instructions!
Brent Johnson - Réponse Partager
After I had finished putting my C930 back together, I noticed that the underside of the original battery had four soft black strips adhered to it, perhaps as a cushion between the battery and the components beneath. It is possible to remove those, and they could be re-applied to the new battery before installing it, but I’m not going to bother going back now to do that.
Those 2 clear strips work like Command adhesives, peal back, then pull - it stretches and detaches from the battery and the laptop. Then the battery just lifts out with ease… They are not really needed for re-installation. Probably more for protection during shipping or hard hits.
Chris B - Réponse Partager
Adding to Brent’s comments. Pulling on those clear tape tabs will completely remove the tape holding the battery down making it very easy to remove the battery. My replacement battery came with 2 new tape strips, so check yours before worrying about trying to save the originals.
Leo L - Réponse Partager
I was able to remove the 4 black, “spongy” strips from the original battery and place them on the new battery. This created a “landing” area for the adhesive strips that remained working the computer housing. All instructions were good and quite thorough. Thank you!
Chris Bearss - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 34
30 derniers jours : 175
Total : 31,018
