Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lexmark MX611de Maintenance Kit Replacement
Ce dont vous avez besoin
    1. Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: étape 1, image 1 de 2 Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: étape 1, image 2 de 2
      • Remove the paper tray
      • Remove the screw securing the right cover to the front of the printer frame.
      • Open the memory access cover that is attached to the right cover
      • Remove the two screws securing the right cover to the RIP shield.
      • Slightly lift the printer, slide the right cover forward, and pull it out and away from the printer
      Demander à FixBot
      Ajouter un commentaire
      • Remove the screw securing the left cover to the front of the printer frame.
      • Release the Two tabs on the bottom of the cover.
      • Pull the cover forward, and remove it from the printer.
      Demander à FixBot
      • Open rear door.
      • Pull the exit door upward to release the hinges, and remove.
      • Remove the two screws securing the rear cover.
      • Remove the cover.
      Demander à FixBot
      • Remove the three screws from the Left Mounting Bracket
      • Two different ways to the next step, dependent on experience and/or confidence.
      • Move the the Mounting Bracket over while extending the Stapler Cable out of the way, The Stapler cable does not have to disconnected.
      • Remove the Stapler Cable and Mounting bracket from the printer frame while feeding the cable through the redrive unit and printer frame.
      • Using a pair of pliers, squeeze the nylon mounts to dislodge the stapler connector, and remove the cable.
      • Remove the three screws from the Right mounting bracket.
      Demander à FixBot
      • Remove the Two screws, and then disconnect the reverse solenoid.
      • Do not disconnect the reverse solenoid cable from the controller board.
      • Remove the Six screws securing the redrive assembly.
      Demander à FixBot
      • Disconnect the cable JEXIT1 from the controller board.
      • Disconnect the Two cables.
      • Remove the Two screws securing the fuser.
      Demander à FixBot
alarson118
Membre depuis le 02/24/15
553 Réputation
3 tutoriels rédigés
Équipe
Tech-zone Membre de l'équipe Tech-zone
Business
2 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 55
Total : 6,000
