Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech G Cloud L2-R2 Trigger Replacement
Ce dont vous avez besoin
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: étape 1, image 1 de 2 Logitech G Cloud L2-R2 Trigger Replacement, Case: étape 1, image 2 de 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech G Cloud L2-R2 Trigger Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    Demander à FixBot
  3. Logitech G Cloud L2-R2 Trigger Replacement: étape 3, image 1 de 2 Logitech G Cloud L2-R2 Trigger Replacement: étape 3, image 2 de 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    Demander à FixBot
  4. Logitech G Cloud L2-R2 Trigger Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    Demander à FixBot
  5. Logitech G Cloud L2-R2 Trigger Replacement: étape 5, image 1 de 2 Logitech G Cloud L2-R2 Trigger Replacement: étape 5, image 2 de 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    Demander à FixBot
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: étape 6, image 1 de 2 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: étape 6, image 2 de 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    Demander à FixBot
Spencer Davis
Membre depuis le 01/23/25
517 Réputation
6 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 59
Total : 590
