Introduction
Use this guide to replace the side buttons board in your Logitech G502 Hero wired gaming mouse.
If your side buttons aren't working, are sticking, or aren't clicking all the way, you may need to replace the side buttons board.
Ce dont vous avez besoin
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Lift the weight door by its tab and remove it.
If you have weights in the compartment, remove them.
Lift the top shell straight up and remove it, making sure the main mouse cable stays attached to the bottom shell.
Gently lift the side buttons board straight up and out of its slot.
Gently pull the board straight up so the cable comes out of its socket.
Insert the cable into its socket so the blue tab is on the same side as the connector's latch.
Use the flat end of a spudger to push the latch straight down into its locked position.
Set the board down on a clean, ESD‑safe surface so the side with the cable is facing up.
Use the point of a spudger to lift the locking flap on the ZIF connector.
Pull the cable straight out of its socket.
