Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech G710+ Disassembly
Ce dont vous avez besoin
    1. Logitech G710+ Disassembly, Body: étape 1, image 1 de 1
      • Remove 14 Phillips screws on the bottom of the kayboard.
      • Use a plastic tool to release the clips holding the case together.
      • There are two hidden clips above the left and right arrow keys.
      • Gently pry the two halves of the case apart.
      • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
      Demander à FixBot
      Ajouter un commentaire
    2. Logitech G710+ Disassembly, Mother board: étape 2, image 1 de 3 Logitech G710+ Disassembly, Mother board: étape 2, image 2 de 3 Logitech G710+ Disassembly, Mother board: étape 2, image 3 de 3
      • Unscrew the one screw holding on the ground and pull out the cables.
      • A good way of getting the cables out is by putting a screwdriver right there and twisting.
      • Unscrew this screw
      Demander à FixBot
    3. Logitech G710+ Disassembly, Scroll Wheel: étape 3, image 1 de 1
      • The light thing comes out with a wiggle.
      • The scroll wheel on the other is harder because you have to melt or brake the supports off.
      • Then you have to get the wheel out which comes out with a very gentle wiggle.
      Demander à FixBot
    4. Logitech G710+ Disassembly, Pads: étape 4, image 1 de 1
      • You can then take off the little pads
      Demander à FixBot
6 autres ont terminé cette réparation.
Jackson Poer
Membre depuis le 04/08/17
711 Réputation
2 tutoriels rédigés
3 commentaires de tutoriel
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - Réponse Partager
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - Réponse Partager
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 17
30 derniers jours : 94
Total : 9,827
