Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech Harmony 650 Button Replacement
Ce dont vous avez besoin
  1. Logitech Harmony 650 Button Replacement, Case: étape 1, image 1 de 2 Logitech Harmony 650 Button Replacement, Case: étape 1, image 2 de 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech Harmony 650 Button Replacement: étape 2, image 1 de 1
    • Remove the batteries using the silver pull tab.
    Demander à FixBot
  3. Logitech Harmony 650 Button Replacement: étape 3, image 1 de 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    Demander à FixBot
  4. Logitech Harmony 650 Button Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    Demander à FixBot
  5. Logitech Harmony 650 Button Replacement: étape 5, image 1 de 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    Demander à FixBot
  6. Logitech Harmony 650 Button Replacement: étape 6, image 1 de 2 Logitech Harmony 650 Button Replacement: étape 6, image 2 de 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    Demander à FixBot
  7. Logitech Harmony 650 Button Replacement: étape 7, image 1 de 1
    • Remove the rear cover.
    Demander à FixBot
  8. Logitech Harmony 650 Button Replacement, Motherboard: étape 8, image 1 de 2 Logitech Harmony 650 Button Replacement, Motherboard: étape 8, image 2 de 2
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
    Demander à FixBot
  9. Logitech Harmony 650 Button Replacement: étape 9, image 1 de 1
    • Remove the motherboard by gently pulling it away from the case.
    Demander à FixBot
  10. Logitech Harmony 650 Button Replacement, Button: étape 10, image 1 de 1
    • Using a spudger, gently pry the bottom retaining place from the front case.
    Demander à FixBot
  11. Logitech Harmony 650 Button Replacement: étape 11, image 1 de 2 Logitech Harmony 650 Button Replacement: étape 11, image 2 de 2
    • Peel away both the upper and lower sets of buttons using your fingers.
    Demander à FixBot
15 autres ont terminé cette réparation.
Connor Gallagher
Membre depuis le 01/11/16
1 036 Réputation
5 tutoriels rédigés
8 commentaires de tutoriel
Good instructions. Where can I purchase new buttons???
Michael Freeman - Réponse Partager
Hello, I would recommend looking on eBay for a broken remote with a good membrane, also check craigslist or potentially amazon. A quick search for one and I couldn't find a membrane.
Austin K - Réponse Partager
I also am looking for a new button membrane, any ideas? gimmick73@hotmail.com
gimmick73 - Réponse Partager
Good advice. I bought a used one from ebay to replace the one I bought brand new from bestbuy and promptly broke the screen by dropping it on the kitchen floor. I plan on replacing the worn buttons on the working used replacement with the buttons from my broken one, and perhaps the case as well. Will let you know how it works out.
Jeremiah Behrens - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 57
Total : 14,731
