Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech Harmony 650 Case Replacement
Ce dont vous avez besoin
    1. Logitech Harmony 650 Case Replacement, Case: étape 1, image 1 de 2 Logitech Harmony 650 Case Replacement, Case: étape 1, image 2 de 2
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      Demander à FixBot
      Ajouter un commentaire
    2. Logitech Harmony 650 Case Replacement: étape 2, image 1 de 1
      • Remove the batteries using the silver pull tab.
      Demander à FixBot
    3. Logitech Harmony 650 Case Replacement: étape 3, image 1 de 1
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      Demander à FixBot
    4. Logitech Harmony 650 Case Replacement: étape 4, image 1 de 1
      Outil utilisé dans cette étape :
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      Demander à FixBot
    5. Logitech Harmony 650 Case Replacement: étape 5, image 1 de 1
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      Demander à FixBot
    6. Logitech Harmony 650 Case Replacement: étape 6, image 1 de 2 Logitech Harmony 650 Case Replacement: étape 6, image 2 de 2
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      Demander à FixBot
    7. Logitech Harmony 650 Case Replacement: étape 7, image 1 de 1
      • Remove the rear cover.
      Demander à FixBot
5 autres ont terminé cette réparation.
Connor Gallagher
Membre depuis le 01/11/16
1 036 Réputation
5 tutoriels rédigés
1 commentaire de tutoriel
Thanks for the fix. Now I can get on replacing the corroded battery contacts. Many thanks.
Kevin Bonney - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 35
Total : 3,700
