Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech Harmony Touch Buttons Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Touch Buttons Replacement, Buttons: étape 1, image 1 de 3 Logitech Harmony Touch Buttons Replacement, Buttons: étape 1, image 2 de 3 Logitech Harmony Touch Buttons Replacement, Buttons: étape 1, image 3 de 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech Harmony Touch Buttons Replacement: étape 2, image 1 de 3 Logitech Harmony Touch Buttons Replacement: étape 2, image 2 de 3 Logitech Harmony Touch Buttons Replacement: étape 2, image 3 de 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
    Demander à FixBot
  3. Logitech Harmony Touch Buttons Replacement: étape 3, image 1 de 3 Logitech Harmony Touch Buttons Replacement: étape 3, image 2 de 3 Logitech Harmony Touch Buttons Replacement: étape 3, image 3 de 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
    Demander à FixBot
  4. Logitech Harmony Touch Buttons Replacement: étape 4, image 1 de 2 Logitech Harmony Touch Buttons Replacement: étape 4, image 2 de 2
    • Remove the buttons from the case.
    Demander à FixBot
2 autres ont terminé cette réparation.
Nicholas Townsend
Membre depuis le 09/25/17
285 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 1,902
